drawing file is not valid (Autocad 2017)
ahmadov.nurlan
Message 1 of 21
ahmadov.nurlan
The drawing is not opening Autocad 2017 drawing file is not valid
Replies (20)
Message 2 of 21
dbroad
How did you create it?  Have you tried to open it with recover?  When I open it with wordpad, I see this:
(DWF V06.00)PK.............
Does that tell you anything?  It tells me that it is a drawing plot, not a drawing.  Change the file extension to DWF.
Architect, Registered NC, VA, SC, & GA.
Message 3 of 21
imadHabash
i try a lot to open the file but it seems that it's corrupted for some reason... i suggest to do the follow:
  1. Look in the same directory where the DWG resides and see if there is a BAK file of the same name. If so, rename the BAK extension to DWG and see if the file can then be opened.
  2. Look in C:\Windows\Temp for files with an SV$ extension. If any exist with a similar name to the corrupted DWG file, then rename the extension to DWG and see if it can then be opened.
hope that help.. Good Luck..
Imad Habash
Message 4 of 21
ahmadov.nurlan
I have not BAK file..This drawing was sent by someone else
Message 5 of 21
ahmadov.nurlan
Message 6 of 21
imadHabash
Okay... call him to send another CAD file and check with him in what version did he save it to compare it with your one.
Imad Habash
Message 7 of 21
ahmadov.nurlan
im using the latest version - 2017 and it should support the all the previous versions. And i have no connections with the creator of the cad file
Message 8 of 21
rkmcswain
OP - see post #2.
This is not a DWG file, it's a DWF file.
Rename it and open it here: https://a360.autodesk.com/viewer/
Message 9 of 21
dbroad
Thanks for the solution credit.  Using a DWF file is just as easy and almost as convenient as using a drawing.  Use the dwfattach command to bring it into your drawing.  You should be able to use wipeouts or clipping to cut out the parts you don't need.
Message 10 of 21
ahmadov.nurlan
how to?
Message 11 of 21
ahmadov.nurlan
This is not happening
Message 12 of 21
rkmcswain
"What" is not happening?
Please quote the relevant portion(s) of the message to which you are replying, because this forum system does not indicate it for us. Thanks.
Message 13 of 21
dbroad
To bring a DWF into a drawing, use DWFATTACH command.  (You need to rename first so that the file extension is DWF). To mask, draw a closed polyline (with no curved edges).  Then use the wipeout command to mask off the items you want to change.  Then draw over them with the changes.  The xclip command might work on attached DWF files.  I admit that I haven't tried that because I would have been the DWF creator and would have had the DWG file.
Message 14 of 21
rkmcswain
Actually, you can use the DWFCLIP command to do this.
Message 15 of 21
ahmadov.nurlan
I don't rename the file extension is DWF
Message 16 of 21
rkmcswain
That is not really a sentence.
Can you restate your question or statement again please?
Message 17 of 21
ahmadov.nurlan
I didn't create this file.I have not BAK file..This drawing was sent by someone else
Message 18 of 21
rkmcswain
I have to repeat post 8.
See post #2.
Message 19 of 21
dbroad
@ahmadov.nurlan,
If you are having trouble renaming the file, be sure to use the file explorer view tab (Windows 10), Make sure "file name extensions" is checked.  This will allow you to rename the file extension.  If you turn off the extensions, it is difficult to rename the file.
Message 20 of 21
ahmadov.nurlan
Thanks Opened this method, but did not open the original drawing..I need original drawing
