Announcements
AUTOCAD project
AUTOCAD project
I did the projects before I read the autocad textbook and he said he's not happy with it. Now I read the textbook. Why is it not okay and what improvements can I put in it? It's in interior design.
Replies (31)
rkmcswain
Who is "he"?
What textbook?
Do you have any remarks from 'him' as to what is "wrong"?
R.K. McSwain     | CADpanacea | on twitter
He is Reginald the person who is taking the course which is from Creators and Designers, Bangalore. I was not well for the first half of the course because I was hearing voices and thought the course wasn't right data. I did a AutoCAD course during that time. After I realised the voices weren't real I couldn't understand the textbooks and youtube videos. Now I can understand them. The textbook I finished is AutoCAD 2014 in Simple Steps by Dreamtech which teaches plans. DesignCentre doesn't have 3d blocks. Is blocks used for 3d also? Reginald said he wants windows, veg and non-veg separate in restaurant.
Patchy
Needs a lot of fixing, use RECTANGLE command and TRIM to make this drawing look presentable.
I'm doing that. Is DesignCentre enough or should I download the templates from the autodesk website. Because my brother said they have a virus. And are there blocks for 3d?
TheCADnoob
for starters it looks bad. It does not look like a completed project. Clean it up and straighten lines which need to be straightened and use paper space to frame the areas of the drawing.
Knowing how to use autocad is not equivalent to being able to create good completed drawings. You might need to study how to create consistent nice looking drawings.
Ultimately drawings are a form of communication and several parts of this drawing are confusing and unclear and are not aesthetically appealing. Ill upload a screencast in a little bit to show an area i cleaned and centered.
make it look like something like this:
 interior-design-floor-plans-1
CADnoob
Patchy
You said: I need to have plans with walls, windows and measurements to show the city my remodeling plans.
Call your City Planning Dept. and ask.
Not here in my City that they want 3d drawings.
If you really want to make your drawing 3d, your 2d drawings that you have now is far away from trying 3d.
You can curse at me if you want.
TheCADnoob
In this screen cast i created a make shift title black and put it in paper space and then i cleaned up the teller area. The entire drawing needs to be cleaned and standardized, but this is an example of what that might look like. There is a lot of work left but you have a pretty good start on it.
CADnoob
I loved it. Could you send me the drawing which you just did?
TheCADnoob
That was done on a student license so unfortunately i cannot.
CADnoob
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
I have your drawing open and the first thing I notice is that everything is drawn on one layer. This limits how you can manipulate your views for different parts of your project. For instance, if you had to show a plan that illustrates items to be demolished before construction can begin, you don't have a layer for that. If you need to do a reflected ceiling plan, there is no way to turn off the doors and casework.
Next, I see that there are no blocks being utilized. Blocks are used to reduce the number of drawing entities, help to manage reoccurring parts and also to provide consistency in the drawing. You can even count blocks using the software rather than doing it manually
I also see a bunch of lines drawn on top of other lines which I am guessing are not intentional and can make editing the drawing more difficult.
There are a bunch of good tutorial videos on YouTube and also on Lynda.com that might get you further. Please start a new thread if you have specific questions regarding features or processes with which you need help.
John Vellek
rkmcswain
To expand on Blocks some more....
Whenever you have identical items drawn, consider making that into a block. For example, say you are drawing a room full of chairs, and suppose each chair is composed of 25 lines, and 20 arcs. If you draw 40 chairs, you would have 1,000 lines and 800 arcs. But if you make that chair into a block, and insert the block 40 times instead of copying the 45 entity chair around 40 times, then the DWG file only has to keep track of the 45 entities that define the chair, and the 40 locations (and rotation/scale) for each "insertion" of that block.
Secondly, using that same example, if you had to make an edit to all 40 chairs, that might take a lot of time. But if your "chair" was a block, you only have to edit the block one time and all 40 insertions of it automatically update.
Are the restaurant templates free on the web? Should they be of the right measurements. Because I don't know the measurements and my classmates are not answering the phone .
TheCADnoob
Likley you will not find a template that has the particulars of the measurements you need. Since you missed so much of the course would you be able to withdraw from the course and take it next term? it would probably better server you and your needs if you are studying towards an industry that uses CAD programs.
CADnoob
john.vellek
Hi @Anonymous,
Blocks are available all over the web. Some are constructed by users and others by manufacturers. You can also use the Seek function in AutoCAD to find symbols as well as the Autodesk App Store to possibly find libraries.
While i could point you to additional resources, I hesitate as there are likely differences in design dimension and criteria based upon region. I encourage you to take a look at the above resources as well as to do a little searching on the Internet. I can also attach some blocks from my personal libraries if you tell me specifically for what you are looking.
John Vellek
You're nice. He said to me to put 2-seaters, 4-seaters and 8-seaters in the restaurant.  I'll find out from him what I need to put in kitchen and ATM and managers room etc. Could you send me blocks for 2-seaters, 4-seaters and 8-seaters? I'm working on restaurant. I deleted the furniture in it and drew 2-seaters but it isn't looking good.
john.vellek
Hi @Anonymous,
Here is one of my library files that contain some table/seating blocks that might work for you. I suggest you take a look at the file and then use Design Center to access the blocks. This will allow you to select a block and insert it into your working drawing by drag and drop.
John Vellek
I downloaded it. But how do I put it into Design Centre?
john.vellek
Hi @Anonymous,
Select the Insert Tab from your Ribbon menu. Towards the right side you will see the icon for Design Center. Click on it to open the tool. Then you can browse to the file you downloaded. Then select Blocks and it will display all of the blocks in the file. If you see the block you want to insert, click on it and then drag it into your current drawing.
John Vellek
I did the hotel. Hotel is the first drawing. But how do I put washbasin in bathroom when Design Centre has only sink. What is a luggage rack? I'm supposed to put one at the entrance.  How do I draw TV and cupboard? The TV is from the top.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
