drawing file is not valid (Autocad 2017)
ahmadov.nurlan
ahmadov.nurlan
The drawing is not opening Autocad 2017 drawing file is not valid
0 Me gusta
Responder
Soluciones aceptadas (1)
4.115 Vistas
20 Respuestas
Respuestas (20)
dbroad
Solución aceptada
How did you create it?  Have you tried to open it with recover?  When I open it with wordpad, I see this:
(DWF V06.00)PK.............
Does that tell you anything?  It tells me that it is a drawing plot, not a drawing.  Change the file extension to DWF.
Architect, Registered NC, VA, SC, & GA.
0 Me gusta
imadHabash
i try a lot to open the file but it seems that it's corrupted for some reason... i suggest to do the follow:
  1. Look in the same directory where the DWG resides and see if there is a BAK file of the same name. If so, rename the BAK extension to DWG and see if the file can then be opened.
  2. Look in C:\Windows\Temp for files with an SV$ extension. If any exist with a similar name to the corrupted DWG file, then rename the extension to DWG and see if it can then be opened.
hope that help.. Good Luck..
Imad Habash
0 Me gusta
ahmadov.nurlan
I have not BAK file..This drawing was sent by someone else
0 Me gusta
ahmadov.nurlan
0 Me gusta
imadHabash
Okay... call him to send another CAD file and check with him in what version did he save it to compare it with your one.
Imad Habash
0 Me gusta
ahmadov.nurlan
im using the latest version - 2017 and it should support the all the previous versions. And i have no connections with the creator of the cad file
0 Me gusta
rkmcswain
OP - see post #2.
This is not a DWG file, it's a DWF file.
Rename it and open it here: https://a360.autodesk.com/viewer/
0 Me gusta
dbroad
Thanks for the solution credit.  Using a DWF file is just as easy and almost as convenient as using a drawing.  Use the dwfattach command to bring it into your drawing.  You should be able to use wipeouts or clipping to cut out the parts you don't need.
0 Me gusta
ahmadov.nurlan
how to?
0 Me gusta
ahmadov.nurlan
This is not happening
0 Me gusta
rkmcswain
"What" is not happening?
Please quote the relevant portion(s) of the message to which you are replying, because this forum system does not indicate it for us. Thanks.
0 Me gusta
dbroad
To bring a DWF into a drawing, use DWFATTACH command.  (You need to rename first so that the file extension is DWF). To mask, draw a closed polyline (with no curved edges).  Then use the wipeout command to mask off the items you want to change.  Then draw over them with the changes.  The xclip command might work on attached DWF files.  I admit that I haven't tried that because I would have been the DWF creator and would have had the DWG file.
0 Me gusta
rkmcswain
Actually, you can use the DWFCLIP command to do this.
0 Me gusta
ahmadov.nurlan
I don't rename the file extension is DWF
0 Me gusta
rkmcswain
That is not really a sentence.
Can you restate your question or statement again please?
0 Me gusta
ahmadov.nurlan
I didn't create this file.I have not BAK file..This drawing was sent by someone else
0 Me gusta
rkmcswain
I have to repeat post 8.
See post #2.
0 Me gusta
dbroad
@ahmadov.nurlan,
If you are having trouble renaming the file, be sure to use the file explorer view tab (Windows 10), Make sure "file name extensions" is checked.  This will allow you to rename the file extension.  If you turn off the extensions, it is difficult to rename the file.
0 Me gusta
ahmadov.nurlan
Thanks Opened this method, but did not open the original drawing..I need original drawing
0 Me gusta
