AutoCAD Forum
Drawing direction in pdf file
8 REPLIES 8
Message 1 of 9
Weblius
569 Views, 8 Replies
Weblius
Hi all
I'm drawing a map with AutoCad, but I have a problem with printing. In the drawing, north is where it should be, but I want the building on the map to be in the same line in the pdf output as the paper sheet.
For printing, the drawing should be turned less than or more than 90 degrees. Is it possible to do this so that this only rotates in the pdf file?
I don't want to rotate the drawing in the model.
Hi all
8 REPLIES 8
Message 2 of 9
TomBeauford
in reply to: Weblius
TomBeauford
Why aren't you using Layout with viewports for printing?
It shouldn't matter what angle the Layout viewport is twisted you should be able to plot it at 90° or 180° to fit the paper while plotting or outputting to PDF.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
2023
Message 3 of 9
Valentin-WSP
Valentin-WSP
@Weblius ,
Yes.
Go to layout and use the ALIGNSPACE (Express Tool).
Select the first and second point in Model to align with a first and second point in Paper space.
Then set an appropriate scale (AutoCAD 2022 Help | About Scaling Views in Layout Viewports | Autodesk)
AutoCAD 2023 Help | ALIGNSPACE (Express Tool) | Autodesk
(Before ALIGNSPACE)     (After ALIGNSPACE)
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
@Weblius ,
Yes.
Emilio Valentin
Message 4 of 9
Weblius
in reply to: Valentin-WSP
Weblius
Thanks, this works.
Does this command work in Autocad LT?
Thanks, this works.
Message 5 of 9
Valentin-WSP
Valentin-WSP
@Weblius wrote:
Thanks, this works.
Emilio Valentin
@Weblius wrote:
Thanks, this works.
Emilio Valentin
Message 6 of 9
pendean
pendean
Community Legend
Community Legend
@Weblius wrote:
...Does this command work in Autocad LT?...
Are you an LT user? Then you are in the wrong forum, so many of the replies will rarely apply to you if no one knows this. Confirm please.
Message 7 of 9
Weblius
in reply to: pendean
Weblius
I use both Autocad and LT.
I'm interested in whether the LT has this same function.
Message 8 of 9
cadffm
cadffm
Command UCS (option z-rotation or object)
followd by command PLAN
Sebastian
Sebastian
Message 9 of 9
pendean
pendean
Community Legend
Community Legend
No, that was already posted as a reply to you
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Express-Tools-and-...
AutoCAD Inside the Factory
