- Mute
- Permalink
- Report
Hi all
I'm drawing a map with AutoCad, but I have a problem with printing. In the drawing, north is where it should be, but I want the building on the map to be in the same line in the pdf output as the paper sheet.
For printing, the drawing should be turned less than or more than 90 degrees. Is it possible to do this so that this only rotates in the pdf file?
I don't want to rotate the drawing in the model.
