Drawing direction in pdf file
Weblius
Weblius
Hi all
I'm drawing a map with AutoCad, but I have a problem with printing. In the drawing, north is where it should be, but I want the building on the map to be in the same line in the pdf output as the paper sheet.
For printing, the drawing should be turned less than or more than 90 degrees. Is it possible to do this so that this only rotates in the pdf file?
I don't want to rotate the drawing in the model.
Replies (8)
TomBeauford
Why aren't you using Layout with viewports for printing?
It shouldn't matter what angle the Layout viewport is twisted you should be able to plot it at 90° or 180° to fit the paper while plotting or outputting to PDF.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
Valentin_CAD
@Weblius ,
Yes.
Go to layout and use the ALIGNSPACE (Express Tool).
Select the first and second point in Model to align with a first and second point in Paper space.
Then set an appropriate scale (AutoCAD 2022 Help | About Scaling Views in Layout Viewports | Autodesk)
AutoCAD 2023 Help | ALIGNSPACE (Express Tool) | Autodesk
(Before ALIGNSPACE)     (After ALIGNSPACE)
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Weblius
Thanks, this works.
Does this command work in Autocad LT?
Valentin_CAD
@Weblius wrote:
Thanks, this works.
Emilio Valentin
pendean
Community Legend
Community Legend
@Weblius wrote:
...Does this command work in Autocad LT?...
Are you an LT user? Then you are in the wrong forum, so many of the replies will rarely apply to you if no one knows this. Confirm please.
Weblius
I use both Autocad and LT.
I'm interested in whether the LT has this same function.
cadffm
Command UCS (option z-rotation or object)
followd by command PLAN
Sebastian
pendean
Community Legend
Community Legend
No, that was already posted as a reply to you
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Express-Tools-and-...
