AutoCAD Forum
Dimensioning text doesn't display!
4 REPLIES 4
449 Views, 4 Replies
The dimensioning text doesn't display when I add a dimension. It only displays an empty textbox when I add a dimension. The same happens when I use DTEXT or MTEXT. Please see the attached file. The frame around the text option is unchecked.
Any help would be much appreciated.
4 REPLIES 4
ennujozlagam
hello, have you check your DIMSTYLE setting,
or QTEXT set to OFF. thanks
in reply to: ennujozlagam
Thanks for your help. I simply set the QTEXT to OFF and it worked.
ennujozlagam
hello, try in QTEXT first > in the command prompt type Qtext and set to OFF and see if solve your issue. thanks
ennujozlagam
no worries, glad to help. thanks
AutoCAD Inside the Factory
