Dimensioning text doesn't display!
No aplicable
The dimensioning text doesn't display when I add a dimension. It only displays an empty textbox when I add a dimension. The same happens when I use DTEXT or MTEXT. Please see the attached file. The frame around the text option is unchecked.
Any help would be much appreciated.
0 Me gusta
Responder
Soluciones aceptadas (2)
527 Vistas
4 Respuestas
Respuestas (4)
ennujozlagam
Solución aceptada
hello, have you check your DIMSTYLE setting,
or QTEXT set to OFF. thanks
0 Me gusta
No aplicable
Thanks for your help. I simply set the QTEXT to OFF and it worked.
0 Me gusta
ennujozlagam
Solución aceptada
hello, try in QTEXT first > in the command prompt type Qtext and set to OFF and see if solve your issue. thanks
0 Me gusta
ennujozlagam
no worries, glad to help. thanks
0 Me gusta
