524 Vistas, 4 Respuestas
Dimensioning text doesn't display!
The dimensioning text doesn't display when I add a dimension. It only displays an empty textbox when I add a dimension. The same happens when I use DTEXT or MTEXT. Please see the attached file. The frame around the text option is unchecked.
Any help would be much appreciated.
ennujozlagam
en respuesta a: Anonymous
hello, have you check your DIMSTYLE setting,
or QTEXT set to OFF. thanks
en respuesta a: ennujozlagam
Thanks for your help. I simply set the QTEXT to OFF and it worked.
ennujozlagam
hello, try in QTEXT first > in the command prompt type Qtext and set to OFF and see if solve your issue. thanks
ennujozlagam
no worries, glad to help. thanks
