AutoCAD Forum
Coordiante system
4 REPLIES 4
252 Views, 4 Replies
Coordiante system
Hello, I have received two separate files. one drawing file and one Tif (underlying map) for the drawing. I have used imageattach and included the image in a new drawing file. when I overlay the other file (drawing) it is not align with the map. I would like some help to be able to coordinately match these two files.
Hamideh
4 REPLIES 4
Alfred.NESWADBA
You might try to use command _ALIGN and see if that helps.
In case you have AutoCAD Map 3D or Autodesk Civil 3D please let us know that, there you can define geographic coordinate systems and transfer geometry from one CS to a different one.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
Thanks Alfred.
I have asked our IT to install civil 3D. but I need to know what is the
coordinate system of each. I have already used Align to scale the tif image
to goodle earth. but when i overly the drawing it doesnt line up on the
tif.
Alfred.NESWADBA
That is correct, you need to get in contact with the creator of that files to know the CS of each dataset.
>> to goodle earth
May I ask the following questions:
  • As you use Google Earth images ... are they placed on real geographic coordinates? Or is the image simply inserted at 0,0,0?
  • Is your other dataset placed on geodatic coordinates? Or also at 0,0,0?
At least you need to know which of your dataset's is using correct coordinates (and units), without that every trial of _ALIGN (or when you have installed Civil 3D) you might try command _ADETRANSFORM or _ADERSHEET would not result in a new correct position of your data.
- alfred -
Alfred NESWADBA
Pointdump
Hami,
Welcome to the Autodesk Forums.
"...I need to know what is the coordinate system of each."
If your Tiff is geo-referenced, the quickest way to find out is Lizardtech's free >>>GeoViewer<<<.GeoViewer_1.png
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Forma Design Contest
