AutoCAD Forum
Construction Lines drifiting away from initially selecting point
12 REPLIES 12
Message 1 of 13
580 Views, 12 Replies
When attempting to create a construction line I usually follow these steps:
1. Select construction line
2. Pick point
3. F8 to toggle ortho if required
At which point the construction line has always rotated about the initial point I selected. Recently however, between step 2 and 3, my construction line does not maintain its initial centre point, it drifts away meaning I then have to use the move command to put it back on the initial point. I can't figure out why this is happening.
Anyone know why this might be happening?
Thanks in advance,
Carl
12 REPLIES 12
Message 2 of 13
ВeekeeCZ
Check OSNAPs... especially perpendicular.
Message 3 of 13
TheCADnoob
are you using snap to grid?
CADnoob
Message 4 of 13
BeekeezCZ/ TheCADnoob,
Thanks for replying, I tried your suggestions but still no luck unfortunately.
I have noticed since posting that the problem only occurs when snapping to a point on a block so maybe it's just a case of exploding the block..
Regards
Carl
Message 5 of 13
TheCADnoob
This further confuses the issue for me.. would you be able to provide a screen capture of whats happening?
CADnoob
Message 6 of 13
in reply to: TheCADnoob
Ok,
See attached pdf. As an example, I have a universal beam cross section (block) and a line (shown in magenta)
Line
Fig 1 - I've clicked construction line on the toolbar, then hovered over an endpoint on the line.
Fig 2 - I've clicked the end point and moved my mouse away, notice how the construction line now freely pivots about this point (or if i turn on ortho I could restrain it in the vertical or horizontal, still about the end point selected though.)
Block
Fig 3 - Again, select construction line on the toolbar, this time hovering over a point on the block.
Fig 4 - When I click the point I was hovering over and move my mouse to place the second point of the construction line, the construction line 'detaches' itself from this point.
Regards
Carl
Message 7 of 13
ВeekeeCZ
Post this as dwg sample to see why is this block so special.
Message 8 of 13
TheCADnoob
are there any contrainghts on the drawing or block? Type in CONSTRAINTBAR
CADnoob
Message 9 of 13
in reply to: ВeekeeCZ
BeekeezCZ,
I can't upload the CAD file, keep getting the error message
'The attachment's construction lines.dwg content type (application/x-pangaeacadsolutions) does not match its file extension and has been removed.'
However, it appears to be polylines that have the problem, not blocks as I initially thought.
I use the structural CAD sections from http://www.cad-steel.co.uk and assumed they were blocks not polylines.
Cheers
Carl
Message 10 of 13
No luck with this command either!
Message 11 of 13
ВeekeeCZ
@Anonymous wrote:
BeekeezCZ,
Cheers
Carl
ZIP it and post it. Or on some other cloud and post a link.
Message 12 of 13
john.vellek
Hi @Anonymous, Please rt-click your drawing file(s) and "Send to" "Compressed Folder". You should then be able to attach the resulting ZIP file to this thread. I look forward to helping you resolve this issue.
John Vellek
Message 13 of 13
john.vellek
HI carl.blewitt,
I am checking back to see if you could attach the drawing onto your post so I can take a look.
John Vellek
Forma Design Contest
