AutoCAD Forum
connection between two solid
2 REPLIES 2
218 Views, 2 Replies
here is in attach the plans for a dam that I have to model in 3D, there is also my dwg file so you can see that I did two part of my area which is the number 10, but there is an extension in the area and I can't do it, I would like to connect the two areas with the deviation of the edge but I'm lost, if someone could help it would be great...
thanks!
2 REPLIES 2
Alfred.NESWADBA
I'm not clear understanding your question, but what you are trying to do with Vanilla AutoCAD and 3D-Solids should be done with Civil 3D. There you have the control for assemblies/sub-assemblies, their height and width and super-elevation along an alignment.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
imadHabash
Since we don't have all the data , i'll give a hint that may help you . try to draw an elevation for your profile then Extrude it as shown below . you have also an option for Path to extrude with .
Imad Habash
Forma Design Contest
