here is in attach the plans for a dam that I have to model in 3D, there is also my dwg file so you can see that I did two part of my area which is the number 10, but there is an extension in the area and I can't do it, I would like to connect the two areas with the deviation of the edge but I'm lost, if someone could help it would be great...
thanks!
I'm not clear understanding your question, but what you are trying to do with Vanilla AutoCAD and 3D-Solids should be done with Civil 3D. There you have the control for assemblies/sub-assemblies, their height and width and super-elevation along an alignment.
- alfred -
Since we don't have all the data , i'll give a hint that may help you . try to draw an elevation for your profile then Extrude it as shown below . you have also an option for Path to extrude with .
