AutoCAD Forum
Change (-)hyphen to (_)underscore in PDF names While exporting PDF
15 REPLIES 15
Message 1 of 16
flowerpapa
2686 Views, 15 Replies
Change (-)hyphen to (_)underscore in PDF names While exporting/printing  PDF in autocad
15 REPLIES 15
Message 2 of 16
pendean
in reply to: flowerpapa
There is nothing built-in to do that: you can get a freeware Windows app to rename files for you if that's an option.
Message 3 of 16
Llam.Tech
I usually use an excel program and a combination of dos/command prompt to do that.
Message 4 of 16
flowerpapa
Could you forward the process of the same
Message 5 of 16
maratovich
Using an additional program, you can specify any name when printing.
This is not a problem in AutoCAD
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Tags (2)
Message 6 of 16
flowerpapa
in reply to: maratovich
Can you post thanks program.
Message 7 of 16
maratovich
Depends on how your formats are created.
Try it. If it does not work out - attach a sample .dwg file
Here is the link to the program
www.kdmsoft.net
Message 8 of 16
flowerpapa
Nope..The think is when I publish my dwg file, it was created with the name of (dwg name-layout name). Is there any option for change that - to _ between dwg name & layout name in AutoCAD itself?
Message 9 of 16
maratovich
In the publication window - publishing options
select - a file with several pages
select - file name
www.kdmsoft.net
Message 10 of 16
flowerpapa
I need the below image notifies that - (marked in blue),  could we change that (-) separator to any character by automatically? Is that possible or not
Message 11 of 16
JTBWorld
It's not possible to change the delimiter. You have to rename the PDF files after they are created or use a 3:rd part app that has the ability to use a custom delimiter.
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
Message 12 of 16
flowerpapa
in reply to: JTBWorld
Is that not possible to change the delimiter by customizing any part?
Message 13 of 16
JTBWorld
No, the Publish command can't be customized.
Jimmy Bergmark
Message 14 of 16
flowerpapa
so sad, Thanks for your valuable replies
Message 15 of 16
JTBWorld
If you would consider a 3:rd party solution feel free to contact us.
Jimmy Bergmark
Message 16 of 16
Llam.Tech
I created one video specific to this question. This is a third party solution.
Find attached link.
LlamTech
Forma Design Contest
AutoCAD Beta
