Change (-)hyphen to (_)underscore in PDF names While exporting/printing PDF in autocad
Solved by pendean. Go to Solution.
I usually use an excel program and a combination of dos/command prompt to do that.
Using an additional program, you can specify any name when printing.
This is not a problem in AutoCAD
Depends on how your formats are created.
Try it. If it does not work out - attach a sample .dwg file
Here is the link to the program
In the publication window - publishing options
select - a file with several pages
select - file name
I need the below image notifies that - (marked in blue), could we change that (-) separator to any character by automatically? Is that possible or not
It's not possible to change the delimiter. You have to rename the PDF files after they are created or use a 3:rd part app that has the ability to use a custom delimiter.
No, the Publish command can't be customized.
If you would consider a 3:rd party solution feel free to contact us.
I created one video specific to this question. This is a third party solution.
Find attached link.
LlamTech
