Solved by Alfred.NESWADBA. Go to Solution.
Hi @Anonymous,
If I were doing this I would likely use SLICE to trim off the top of the vertical members. Give it a try and let me know if you have luck or get stuck.
You could also grip select the ends of the verticals and drag them down.
i tried dragging grips but it pulls the hieght of the whole frome not each corner cant seen to slice it ?
please find this video which shows how to change the middle objects and UNION them at the end.
- alfred -
this is great thank you also how can i cut the top frame back where it overhangs the low end
tegards
ian
thank you
you have got the tip with command _SLICE from @john.vellek already 😉
- alfred -
