AutoCAD Forum
Cannot plot after enabling transparency option Autocad2012
5 REPLIES 5
1093 Views, 5 Replies
I have a trouble in plotting with hatches (transparency 70%) that once I enabling the transparency option the whole file just plotted blankly.. not only the hatches but all the other lines are gone. But after I untick the transparency box in the plot setting, everything comes out fine, even the hatches are plotted with the correct colors yet I do not want it as a solid colour block. And also one other weird thing is that once i turn on the transparency option the plotting time become so slow.
Thank you!
5 REPLIES 5
Vinayv4v
Can you please upload the dwg file to take a lookn or a screen shot of the plot settings you are using.
Cheers,
Vinay Vijayakumaran
in reply to: Vinayv4v
The Plot setting
Michiel.Valcke
without your .dwg and an example .pdf it will be hard to say what is going wrong.
I do wonder however why you're not using 'DWG to PDF.pc3' but instead choose to use the Adobe PDF plotter.
in reply to: Michiel.Valcke
Ooo just change the setting to plot from dwg to pdf and IT WORKS!!! Thanks a lot!
Michiel.Valcke
I'm happy to help ^^
Forma Design Contest
AutoCAD Beta
