Cannot plot after enabling transparency option Autocad2012
I have a trouble in plotting with hatches (transparency 70%) that once I enabling the transparency option the whole file just plotted blankly.. not only the hatches but all the other lines are gone. But after I untick the transparency box in the plot setting, everything comes out fine, even the hatches are plotted with the correct colors yet I do not want it as a solid colour block. And also one other weird thing is that once i turn on the transparency option the plotting time become so slow.
Thank you!
Vinayv4v
Can you please upload the dwg file to take a lookn or a screen shot of the plot settings you are using.
Cheers,
Vinay Vijayakumaran
The Plot setting
Michiel.Valcke
without your .dwg and an example .pdf it will be hard to say what is going wrong.
I do wonder however why you're not using 'DWG to PDF.pc3' but instead choose to use the Adobe PDF plotter.
Ooo just change the setting to plot from dwg to pdf and IT WORKS!!! Thanks a lot!
Michiel.Valcke
I'm happy to help ^^
