Cancel of the mode of saving the same file in two formats: DWG and DWFX.
AlexBern44
AlexBern44
For some unknown reason, my Autocad saves a normal DWG file also in DWFX format. As a result, I have 2 files in my documents. It's most likely related to some variable that I accidentally changed. Does anyone know how to get this back so that the end result is just one DWG?
Alex
Valentin_CAD
@AlexBern44 ,
Please provide the operating system and AutoCAD version. Also let us know if you are saving to the cloud.
Consider the suggestions from this link:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
AlexBern44
Valentin-WSP,
Win 7
AutoCAD 2016
I am not using the cloud.
Thanks for the link, but the solution mentioned in that thread, in particular the ISAVEBAK variable, did not solve the problem
Valentin_CAD
@AlexBern44 ,
Interesting issue.
Set the ISAVEPERCENT = 0.
In your OPTIONS > Open and Save, set the Automatic save to 0 and uncheck Create backup copy with each save.  (May be your *.bak is set to open as DWFX - consider checking).
Also consider SAVEAS > Tools > Options:
Just for fun, also check the same for DWF:
Is your profile to Default AutoCAD?
Do you get the same issue with a NEW empty drawing?
Do you get the same issue with SAVEAS?
Otherwise resetting AutoCAD to defaults should fix this (see How to reset AutoCAD to defaults).
Emilio Valentin
Alfred.NESWADBA
Please start command _OPTIONS, activate tab "Plot and Publish" and uncheck this:
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
