I use Extrude on the yellow group, select Solid as output but a surface is created
The 2 splines have elevation 0
Solved by Patchy. Go to Solution.
HI,
it's work fine here . but you may need to check from Extrude command your MOde type . see attached CAD file . also you can use PRESSPULL command and select inner space .
Imad Habash
SCNR ... have you looked to all the threads you created with the same question >>>click<<<?
...and some of them with the same result _PRESSPULL as @imadHabash showed you (again)...
If you don't remember the command or the workflow, please first you the search option in the forum! 😉
- alfred -
