AutoCAD Forum
Can't extrude to a solid, creates surface
3 REPLIES 3
Karol-Or
1437 Views, 3 Replies
I use Extrude on the yellow group, select Solid as output but a surface is created
The 2 splines have elevation 0
3 REPLIES 3
Patchy
in reply to: Karol-Or
Why not use REGION and then Extrude?
imadHabash
HI,
it's work fine here . but you may need to check from Extrude command your MOde type . see attached CAD file . also you can use PRESSPULL command and select inner space .
Imad Habash
Alfred.NESWADBA
SCNR ... have you looked to all the threads you created with the same question >>>click<<<?
...and some of them with the same result _PRESSPULL as @imadHabash showed you (again)...
If you don't remember the command or the workflow, please first you the search option in the forum! 😉
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Forma Design Contest
AutoCAD Beta
