AutoCAD Forum
Can't Dimension to Circle Edge
9 REPLIES 9
Message 1 of 10
3376 Views, 9 Replies
I'm having a dimensioning problem, and it doesn't seem to matter if it something I have created or something a customer has sent to me.
When I attempt to dimension a circle, I get the following error message:
Select arc or circle:
Object selected is not an arc, circle or polyline arc segment.
A few days back, I got this error message, and when I came in the next morning, I was able to dimension the circle.
Has anyone else experienced this problem, and what was the fix?
Thank you so much for your help.
9 REPLIES 9
Message 2 of 10
pendean
Can you post a sample DWG with a circle that is not a circle?
And what dimension command did you use with it.
Message 3 of 10
in reply to: pendean
I've attached the latest part that gives me that message. Since it doesn't matter where it was created, I would think it's a setting issue, but I have no idea what setting to change.
As far as how I dimension, I go to the hole diameter icon in the Dimension section of Annotate.
Message 4 of 10
pendean
Your sample seems just fine here: R2013 (plain), DWG file attached with dimensions.
Message 5 of 10
I was pretty sure there was nothing wrong with the file I attached, which is why I'm asking if there is some sort of setting I need to change so it will dimension correctly the first time.
Message 6 of 10
pendean
AFAIK there is no 'setting' to make DIMRADIUS or DIMDIAMETER commands stop working on Arc or Circle objects in a file.
Perhaps is a missed selection click, or the objects are not what they appear to be?
Message 7 of 10
Steve_Bessette
From opening your .dxf file, I noticed that it is in the 2000 format.  Do you experience the same behavior whe the .dxf file is in the 2013 format?
Steve Bessette
Support Specialist
Product Support
Autodesk, Inc.
Message 8 of 10
in reply to: Steve_Bessette
Thank you.
It doesn't matter what format the part is in, nor does it matter if it's a .DXF or .DWG.
Message 9 of 10
nestly2
This happens when using AutoCAD Mechanical, or vanilla AutoCAD.... or both?
Message 10 of 10
in reply to: nestly2
I have autocad mechanical 2013. I have no idea what the files from customers have been created in.
Like I have in an earlier post, I can come back a day or two later, and it will dimension just fine.
Forma Design Contest
