AutoCAD Forum
Can't Dimension to Circle Edge
9 REPLIES 9
Message 1 of 10
3431 Views, 9 Replies
I'm having a dimensioning problem, and it doesn't seem to matter if it something I have created or something a customer has sent to me.
When I attempt to dimension a circle, I get the following error message:
Select arc or circle:
Object selected is not an arc, circle or polyline arc segment.
A few days back, I got this error message, and when I came in the next morning, I was able to dimension the circle.
Has anyone else experienced this problem, and what was the fix?
Thank you so much for your help.
9 REPLIES 9
Message 2 of 10
pendean
Can you post a sample DWG with a circle that is not a circle?
And what dimension command did you use with it.
Message 3 of 10
in reply to: pendean
I've attached the latest part that gives me that message. Since it doesn't matter where it was created, I would think it's a setting issue, but I have no idea what setting to change.
As far as how I dimension, I go to the hole diameter icon in the Dimension section of Annotate.
Message 4 of 10
pendean
Your sample seems just fine here: R2013 (plain), DWG file attached with dimensions.
Message 5 of 10
I was pretty sure there was nothing wrong with the file I attached, which is why I'm asking if there is some sort of setting I need to change so it will dimension correctly the first time.
Message 6 of 10
pendean
AFAIK there is no 'setting' to make DIMRADIUS or DIMDIAMETER commands stop working on Arc or Circle objects in a file.
Perhaps is a missed selection click, or the objects are not what they appear to be?
Message 7 of 10
Steve_Bessette
From opening your .dxf file, I noticed that it is in the 2000 format.  Do you experience the same behavior whe the .dxf file is in the 2013 format?
Steve Bessette
Support Specialist
Product Support
Message 8 of 10
in reply to: Steve_Bessette
Thank you.
It doesn't matter what format the part is in, nor does it matter if it's a .DXF or .DWG.
Message 9 of 10
nestly2
This happens when using AutoCAD Mechanical, or vanilla AutoCAD.... or both?
Message 10 of 10
in reply to: nestly2
I have autocad mechanical 2013. I have no idea what the files from customers have been created in.
Like I have in an earlier post, I can come back a day or two later, and it will dimension just fine.
AutoCAD Inside the Factory
