Bluebeam plugin not working
Message 1 of 18
I'm posting on behalf of a client. Our client uses bluebeam Revu 2019 and AutoCAD 2020. Bluebeam plugin to create pdfs is enabled in Bluebeam Administrator. It was being used to create 3d pdfs from AutoCAD. The user tries to use the plugin but gets an error in AutoCAD. I have tried disabling/enabling the bluebeam plugin following instructions here.
https://support.bluebeam.com/articles/ive-installed-a-new-version-of-cad-software-how-do-i-get-the-l...
Please see screenshot for the error. Any suggestions on how to solve this are greatly appreciated.
Thank you again.
Replies (17)
Message 2 of 18
did you contact bluebeam support?
not really an Autodesk issue
Message 3 of 18
Alfred.NESWADBA
seems the menu is loaded, but not the plugin itself, otherwise it would not state "unknown command".
(or "BSIPDF" is not a valid command inside this plugin)
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 4 of 18
pendean
Community Legend
Community Legend
Message 5 of 18
JeffryWEdwards
I did not see a resolution to this and I just had a similar issue. This was caused, for me, due to some administrative setting restrictions of the BlueBeam plug-in install folder. I was able to get in touch with an administrator, of my company computer, to make sure that the folder the plug-in had the proper permissions. If you are the admin on your computer, then try to run BlueBeam in Administrator Mode and see if this helps. Maybe that can help you narrow down how to fix this for you. See my image of the prompt that led me to this discovery.
Message 6 of 18
CptnCaveman
Any update on this. Tried latest release of ReVu 20 and MEP 2022.. still get same error. Already checked folder permissions. Still can't get the ReVu add-in to work!
Message 7 of 18
Ed__Jobe
What error are you getting? There are two mentioned in this thread. Did you try contacting Bluebeam support as mentioned? They respond fairly quickly.
Ed
How to post your code.
Message 8 of 18
pendean
Community Legend
Community Legend
@Anonymous Contact BlueBeam Support https://support.bluebeam.com/
Message 9 of 18
CptnCaveman
The original ticket is for Bluebeam plugin not working in AutoCAD products. This still seems to be the same issue with ReVu 20 with Autodesk 2022 products. Yes, I have reached out to support on this. I was checking here if anyone had any updates. Thanks for the response though.
Message 10 of 18
Basam.Yousif
Was this ever resolved?
I just saw a client experiencing this, and escalated to BB support. I will post the solution when I get it.
Message 11 of 18
CptnCaveman
This was not resolved. Only suggestion was removing all software & reinstall then update to latest version. We have since moved onto other PDF solutions. If a fix does come out at some point, then we will revisit this. Good luck!
Message 12 of 18
Ed__Jobe
What error are  you getting? Is it that the menu can't find "BSIPDF"?
As @ mentioned, only the menu is loaded. The plugin itself is not. Go to Bluebeam Administrator>Plugins tab, and make sure that the app is registered with AutoCAD.
Ed
Message 13 of 18
drumroll3
Community Visitor
Community Visitor
I have found out that Bluebeam States this.
You must have a Core or Complete plan for Revu 21 (or a CAD or eXtreme edition license for Revu 20 and below) to use the AutoCAD, Navisworks, Revit, SketchUp and SolidWorks plugins.
Message 14 of 18
makourani
Just check the civil3d/CAD link in the administrator of the bluebeam (see screenshot)
Message 15 of 18
pendean
Community Legend
Community Legend
Message 16 of 18
lczuczuk
Community Visitor
Community Visitor
Reload plug-in thru Bluebeam administrator worked for me.
Message 17 of 18
servicedeskDG3F5
This also worked for me. Disable, Apply, restart AutoCAD, close, Re-enable plugin, Apply, then open AutoCAD again. Should be solved after that
Message 18 of 18
SI_Derrick_V
Observer
Observer
I also had to enable the "menu bar" on top of the screen "customize quick access toolbar" pull down.
