AutoCAD Forum
AutoCAD - Smoothing face along a curved surface
5 REPLIES 5
Zcdncan
371 Views, 5 Replies
I'm looking for a solution to align the edges of my support with the curved surface of the object cradling it. As you can see in the image the edge continues past because I used the fillet tool after creating the objects.
I thought about creating a temporary object to use the subtract tool however while that would be easy it's a lot of steps for such a simple task. Or maybe trying to fillet the edge at such a small angle that it seems lined up - this is obviously not going to be an accurate method.
is there some kind of align tool I can use that will not drag the whole object but only the edges?
Thanks for your help I'm pretty new so I've been doing everything longhand so far.
[ The subject line of this post has been edited to include the product name by @handjonathan ]
5 REPLIES 5
leeminardi
in reply to: Zcdncan
It's not quite clear what you want to do and what are your working constraints.
  1. Do you want to move the brown objects (supports?) such that the end surface of the yellow object is flush with the brown object?
  2. Do you want to modify the end of the yellow objects so that they have the same shape as the brown objects where they come in contact?
The align3d command coupled with the three Boolean commands can be helpful in tasks like this.  Keep in mind that substract and intersect will consume some of the solid objects you might use.
lee.minardi
Zcdncan
in reply to: leeminardi
Hi thanks for the reply,
Sorry I should have been more clear, yes I'd like to modify the end of the lighter piece to match the curve of the brown face. It's that little side profile of the lighter part I'm looking to get rid of.
leeminardi
One way to do the is to make a copy of brown and yellow (copy Enter 0,0,0 Enter).  Move these copies a known distance away so that you do not confuse them  with the originals.
Do a Boolean intersect of brown and yellow (the result may be brown and yellow but you can change it to all yellow).
Use slice to slice and remove one end of the original yellow starting somewhere within brown.
Move the result of the intersect Boolean back by the original offset distance of the copy.
Union the two yellow pieces together.
lee.minardi
Zcdncan
Thanks again for the reply I looked into your solution but I don't think it will add the curvature I need however it gave me another idea on how to get where I need to be.
As is, the center of the yellow diamond shape is flush however I'd like to be able to almost "bend" the corners to follow the face of the brown piece. I've marked it with green what I want to do and red how it currently is to hopefully show what I mean.
Worst case I can do one of the long form solutions I mentioned earlier.
Zcdncan
I ended up just going long form by creating an object on around my original object.
and then using the subtract tool to remove the protrusion.
I have to imagine this is not the quickest solution however it took me to my end goal.
Thanks for your replies!
Forma Design Contest
AutoCAD Beta
