Every time I edit multiline text the text editor rotates the text 270 degrees. How can I fix this?
@Anonymous,
john.vellek has edited your subject line for clarity: multiline text
Solved by john.vellek. Go to Solution.
Try this; While editing the text, right click on it and uncheck Editor Settings-> Always Display WYSIWYG
I suggest to check if Rotation angle = 0 . select the mtext without any command then press Ctrl+1 (see attached image)
if not solved please attache this Mtext as CAD file to check it for you.
Imad Habash
No dice
Nick Rassenti
Associate | Senior Designer
IBI Group
7th Floor - 55 St. Clair Avenue West
Toronto ON M4V 2Y7 Canada
tel +1 416 596 1930 ext 61683 fax +1 416 596 0644
[LinkedIn][Twitter][Instagram][Youtube][Facebook]
[Logo]
NOTE: This email message/attachments may contain privileged and confidential information. If received in error, please notify the sender and delete this e-mail message.
NOTE: Ce courriel peut contenir de l'information privilégiée et confidentielle. Si vous avez recu ce message par erreur, veuillez le mentionner immédiatement à l'expéditeur et effacer ce courriel.
No dice
Nick Rassenti
IBI Group
[Logo]
All the text in the parent drawing behaves like this one. When I edit text it jumps to 270 degrees rotation. After editing I reset to 0 but the next time it's the same story,
Nick Rassenti
IBI Group
[Logo]
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
Have you checked your text style to see if there is anything strange set there? Also, perhaps your view is rotated. Check your DVIEW Twist which allows you to rotate your view.
Please also, if you like, attach your drawing to a post so I can take a closer look.
This is a version of my drawing with just one multinline text. In the original drawing all text behaves this way,
Hih @Anonymous,
It appears that this happens with the font you have selected. If you select something like Arial for instance, it doesn't happen -- comes in with a 0-degree rotation.
I changed the font to Arial and it still rotates the text 270 degrees. This only happens when I edit Mtext.
I am using Autocad 2018. I did not have this issue when I used Autocad 2016.
Post an example with some text in it that behaves this way, so we can test it.
Nick DiPietro
Cad Manager/Monkey
