AutoCAD Mtext rotates 270 degrees
Every time I edit multiline text the text editor rotates the text 270 degrees. How can I fix this?
@Anonymous,
john.vellek has edited your subject line for clarity: multiline text
Replies (14)
ArchD
Try this; While editing the text, right click on it and uncheck Editor Settings-> Always Display WYSIWYG
Archie Dodge
Applications Expert - Infrastructure Solutions Division
IMAGINiT Technologies
imadHabash
I suggest to check if Rotation angle = 0 . select the mtext without any command then press Ctrl+1 (see attached image)
if not solved please attache this Mtext as CAD file to check it for you.
Imad Habash
No dice
Nick Rassenti
Associate | Senior Designer
IBI Group
7th Floor - 55 St. Clair Avenue West
Toronto ON M4V 2Y7 Canada
tel +1 416 596 1930 ext 61683 fax +1 416 596 0644
[LinkedIn][Twitter][Instagram][Youtube][Facebook]
[Logo]
NOTE: This email message/attachments may contain privileged and confidential information. If received in error, please notify the sender and delete this e-mail message.
NOTE: Ce courriel peut contenir de l'information privilƩgiƩe et confidentielle. Si vous avez recu ce message par erreur, veuillez le mentionner immƩdiatement Ơ l'expƩditeur et effacer ce courriel.
No dice
Nick Rassenti
IBI Group
[Logo]
All the text in the parent drawing behaves like this one. When I edit text it jumps to 270 degrees rotation. After editing I reset to 0 but the next time it's the same story,
Nick Rassenti
IBI Group
[Logo]
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
Have you checked your text style to see if there is anything strange set there? Also, perhaps your view is rotated. Check your DVIEW Twist which allows you to rotate your view.
Please also, if you like, attach your drawing to a post so I can take a closer look.
John Vellek
No help here
Nick Rassenti
IBI Group
[Logo]
pendean
Community Legend
Community Legend
screenshots, video or even your DWG file posted here would probably help others help you further.
This is a version of my drawing with just one multinline text. In the original drawing all text behaves this way,
john.vellek
Hih @Anonymous,
It appears that this happens with the font you have selected. If you select something like Arial for instance, it doesn't happen  -- comes in with a 0-degree rotation.
John Vellek
Thanks John, you got it!
Nick Rassenti
IBI Group
[Logo]
I changed the font to Arial and it still rotates the text 270 degrees. This only happens when I edit Mtext.
I am using Autocad 2018. I did not have this issue when I used Autocad 2016.
gotphish001
Post an example with some text in it that behaves this way, so we can test it.
Nick DiPietro
Cad Manager/Monkey
The problem was resolved by using the Arial font without the @.
