AutoCAD Forum
AutoCAD Mtext rotates 270 degrees
14 REPLIES 14
Message 1 of 15
3908 Views, 14 Replies
Every time I edit multiline text the text editor rotates the text 270 degrees. How can I fix this?
@Anonymous,
john.vellek has edited your subject line for clarity: multiline text
@Anonymous,
14 REPLIES 14
Message 2 of 15
ArchD
ArchD
Try this; While editing the text, right click on it and uncheck Editor Settings-> Always Display WYSIWYG
Archie Dodge
Applications Expert - Infrastructure Solutions Division
IMAGINiT Technologies
Archie Dodge
Message 3 of 15
imadHabash
imadHabash
I suggest to check if Rotation angle = 0 . select the mtext without any command then press Ctrl+1 (see attached image)
if not solved please attache this Mtext as CAD file to check it for you.
Imad Habash
Imad Habash
Message 4 of 15
in reply to: ArchD
No dice
Nick Rassenti
Associate | Senior Designer
IBI Group
7th Floor - 55 St. Clair Avenue West
Toronto ON M4V 2Y7 Canada
tel +1 416 596 1930 ext 61683 fax +1 416 596 0644
[LinkedIn][Twitter][Instagram][Youtube][Facebook]
[Logo]
NOTE: This email message/attachments may contain privileged and confidential information. If received in error, please notify the sender and delete this e-mail message.
NOTE: Ce courriel peut contenir de l'information privilégiée et confidentielle. Si vous avez recu ce message par erreur, veuillez le mentionner immédiatement à l'expéditeur et effacer ce courriel.
No dice
Nick Rassenti
IBI Group
[Logo]
Message 5 of 15
in reply to: ArchD
No dice
Nick Rassenti
IBI Group
[Logo]
No dice
Nick Rassenti
IBI Group
[Logo]
Message 6 of 15
in reply to: imadHabash
All the text in the parent drawing behaves like this one. When I edit text it jumps to 270 degrees rotation. After editing I reset to 0 but the next time it's the same story,
Nick Rassenti
IBI Group
[Logo]
Nick Rassenti
IBI Group
[Logo]
Message 7 of 15
john.vellek
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
Have you checked your text style to see if there is anything strange set there? Also, perhaps your view is rotated. Check your DVIEW Twist which allows you to rotate your view.
Please also, if you like, attach your drawing to a post so I can take a closer look.
John Vellek
Hi @Anonymous,
John Vellek
Message 8 of 15
in reply to: john.vellek
No help here
Nick Rassenti
IBI Group
[Logo]
No help here
Nick Rassenti
IBI Group
[Logo]
Message 9 of 15
pendean
pendean
Community Legend
Community Legend
screenshots, video or even your DWG file posted here would probably help others help you further.
Message 10 of 15
This is a version of my drawing with just one multinline text. In the original drawing all text behaves this way,
Message 11 of 15
john.vellek
john.vellek
Hih @Anonymous,
It appears that this happens with the font you have selected. If you select something like Arial for instance, it doesn't happen  -- comes in with a 0-degree rotation.
John Vellek
Hih @Anonymous,
John Vellek
Message 12 of 15
Thanks John, you got it!
Nick Rassenti
IBI Group
[Logo]
Nick Rassenti
IBI Group
[Logo]
Message 13 of 15
I changed the font to Arial and it still rotates the text 270 degrees. This only happens when I edit Mtext.
I am using Autocad 2018. I did not have this issue when I used Autocad 2016.
Message 14 of 15
gotphish001
gotphish001
Post an example with some text in it that behaves this way, so we can test it.
Nick DiPietro
Cad Manager/Monkey
Nick DiPietro
Cad Manager/Monkey
Message 15 of 15
in reply to: gotphish001
The problem was resolved by using the Arial font without the @.
AutoCAD Inside the Factory
