AutoCAD Forum
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
AutoCAD is slooooooow
15 REPLIES 15
Message 1 of 16
hlammerts
604 Views, 15 Replies
Hi Autodesk,
New release do not seem to get faster really. Especially with limited wifi i have the feeling it strummbles a lot. I am digging into features to turn fancy memomy eating things off with vars to tweak. Came across a issue that Autocad variable *Cachemaxtotalsize* can not be 65535 but is max to 30000 for me. Any idea? Does this effect speed positively?
thanks anyway
15 REPLIES 15
Message 2 of 16
cadffm
in reply to: hlammerts
A bit offtopic
32767 i think (/ 65535 2), or?
Sebastian
Message 3 of 16
hlammerts
in reply to: cadffm
No 30000
Message 4 of 16
cadffm
Ok, not on my 2020.1 side, also for CACHEMAXFILES
and now, back to the topic
I think i can not help (without sample files?), i guess the performance hase nothing to do with this fact.
Sebastian
Message 5 of 16
hlammerts
in reply to: cadffm
Good for you, and your newer install.
it has absolutely nothing to do with files.
My point is..  it needs documentation
Message 6 of 16
hlammerts
Sorry, i guess you are right in the first place.
So this value is * 0.5
Why? Duo core AutoCAD ?
Message 7 of 16
RobDraw
Disconnect from or fix Wifi.
Rob
Message 8 of 16
Alfred.NESWADBA
Maybe it helps to start command _DESKTOPANALYTICS and turn of the "agree to data collection" checkbox (if it's on).
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 9 of 16
hlammerts
in reply to: Alfred.NESWADBA
I should rephrase the title of this post.
Else Answers are off topic
Message 10 of 16
Alfred.NESWADBA
Really?
Your statement ... AutoCAD is slow ... especially when Wifi is active.
My answer: turn off DesktopAnalytics ... because my experience is this this could generate a lot of network traffic and makes AutoCAD slower when the network is slow.
May I kindly ask: What is of-topic here?
- alfred -
Alfred NESWADBA
Message 11 of 16
RobDraw
While you're at it, the first couple sentences could use some help, too.
Smart questions get smart answers.
Rob
Message 12 of 16
hlammerts
in reply to: RobDraw
AutoCAD can turn slow because of numerous reasons. My question was about what seems like a bug in a specific variable.
Message 13 of 16
RobDraw
@hlammerts wrote:
AutoCAD can turn slow because of numerous reasons. My question was about a bug in a specific variable. Read it again
It took you until the third sentence to state your question?
Rob
Message 14 of 16
hlammerts
Yes Rob, and i rephased it while reading it. Humor šŸ˜‰
Update from the AutoCAD team
"The team would like to know if you need a value greater than 32767 or were just questioning the limit because of the error string displayed."
I think i do. More cache space means more available memory, right?
So, what's the story of the gone 50%?
Message 15 of 16
Alfred.NESWADBA
And more time to administrate it (hold it up-to-date)!
Bigger cache does not automatically mean better performance.
- alfred -
Alfred NESWADBA
Message 16 of 16
hlammerts
Ok. I was thinking the default 1000 would have a reason. Still, it needs documentation.
Like many other things that slow down or speed up AutoCAD
I was thinking _DESKTOPANALYTICS would do some investigations or runs of some kind. Turns out to be a long short and a gateway for Autodesk to collect all my data. I unchecked it agian to be off. Which i think was  the default in the first place..
Forma Design Contest
AutoCAD Beta
