I was adding feature lines to my surface, and tried to move one up, then I got a fatal error. Now the drawing will open on recover, but will not save without crashing.
RECOVER command found problems in your file here, and it erased a bunch of corrupt entities.
I'm using AutoCAD 2019.1.2
But it still crashes after I recover, when I try to save. It also crashes after audit- which finds over 400 errors.
The drawing will audit and recover. But will not save. The alignments are also not showing up in the toolspace, but I can select them in the plan. Not sure if that gives any clues.
