I use AutoCAD full version to open file create from AutoCAD LT, it can work on 2D model but when try to change to 3D view (ISO view) It doesn't work. I don't know why My current version is product design suit 2021, and AutoCAD LT is 2021 also.
Solved by cadffm. Go to Solution.
Solved by Thomas_Stuehle. Go to Solution.
Can you share the drawing for testing?
Thank you for you try to help but I can't share the file to you it's company work. But I have try to delete some object in the drawing now can work. but need to know the problem because the object I delete is the object I need to work with.
Your secret, your problem 😉
But ok.
what do you mean exactly with " It doesn't work" ?
Please try it with hardware acceleration ON and OFF, command: GRAPHICSCONFIG
" It doesn't work" is the most useless description there is to describe that something does not meet your own expectations.
Think about, we can not see your Screen!
Detailed explanation, Screenshots and the really good https://knowledge.autodesk.com/de/community/screencast
Sebastian
I found this object in drawing has the Z value very close to infinity, see the picture , There are so a lot of object like this, that why I can work in 3D mode, don't know why but this file is create from AutoCAD LT So should have any value on Z coordinate. Or this may happen when open this file in AutoCAD full version. Some one can explain the root cause.
Hello @Anonymous
Welcome to the AutoCAD forum.
In general - the more detailed a description is, the better help can be provided in the forum. This can be via e.g.:
Maybe you could include some of these points / information.
Furthermore:
Could the information provided help you and answer your question?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information. If not please dont hesitate to give an update here in your topic so all members know what´s the progression on your question is and can suggest next steps that might be helpful for you to achieve what you´re looking for.
Best regards,
Thomas
Hello @Anonymous
thanks for your screenshot.
Regarding the heights - does it make a difference if you run either in AutoCAD or in AutoCAD LT the commands to flatten everything in the drawing to Z=0 as described in the article: "How to flatten a drawing in AutoCAD"?
Best regards,
Thomas
>>"don't know why but this file is create from AutoCAD LT So should have any value on Z coordinate."
That's wrong. LT works in the same space like AutoCAD or Civil3D, you always works in a 3D Room!
Usually LT-User don't want to use Z-Value othgers than 0, but if you have one or more objects
in the drawing with z/=0 (for example an Architecture floor) and you uses the object snaps..
your new or moved item to this point.
ObjectSnaps snap X Y AND Z Values from a point.
Sebastian
