AutoCad DirectX runtime failed
2017/6/16:17:34:38	R	DESKTOP-2TO6PSE	=== Setup started on DESKTOP-2TO6PSE by R ===
2017/6/16:17:34:38	R	DESKTOP-2TO6PSE	Path_Length: 158
2017/6/16:17:34:38	R	DESKTOP-2TO6PSE	Current Directory C:\Autodesk\AutoCAD_2018_English_Win_32_64bit_wi_en-us
2017/6/16:17:34:38	R	DESKTOP-2TO6PSE	Launch
2017/6/16:17:34:38	R	DESKTOP-2TO6PSE	CommandLine	/InstallPath C:\Program Files\Autodesk /ContentPath C:\ProgramData\Autodesk /q /url "http://dds.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/AutoCAD_2018_English_Win_32_64bit_wi_en-us_Setup.exe?dummy=0" /skipPI /skipWC /Akamai /skipEULA /SN xxx-xxxxxxxx /PK 001J1
2017/6/16:17:34:38	R	DESKTOP-2TO6PSE	Current Directory C:\Users\R\AppData\Local\Temp\_AI62F0.tmp
2017/6/16:17:34:41	R	DESKTOP-2TO6PSE	Download	Skipped	SETUPMARKER	http://dds.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{54E7768D-798C-4308-895F-756BD209476D}/SETUPMARKER_x64.tar.lzma2
2017/6/16:17:34:41	R	DESKTOP-2TO6PSE	Download	Skipped	SETUP_CONFIG	http://dds.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{54E7768D-798C-4308-895F-756BD209476D}/SETUP_x64.tar.lzma2
2017/6/16:17:34:41	R	DESKTOP-2TO6PSE	Install	CustomCallback	Info	Unable to get custom callback function pointer for [SETUP] CB_SOURCE=C:\Autodesk\AutoCAD_2018_English_Win_32_64bit_wi_en-us\Setup\AcSetupII.dll CB_FUNC=CustomPlatformCheck
2017/6/16:17:34:41	R	DESKTOP-2TO6PSE	Install	CustomCallback	Info	Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/6/16:17:34:46	R	DESKTOP-2TO6PSE	Download	Play	STARTMARKER	http://dds.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{54E7768D-798C-4308-895F-756BD209476D}/STARTMARKER_x64.tar.lzma2
2017/6/16:17:34:46	R	DESKTOP-2TO6PSE	Download	Complete	STARTMARKER	http://dds.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{54E7768D-798C-4308-895F-756BD209476D}/STARTMARKER_x64.tar.lzma2
2017/6/16:17:34:46	R	DESKTOP-2TO6PSE	Download	Skipped	DIRECTX	http://dds.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{54E7768D-798C-4308-895F-756BD209476D}/DIRECTX.tar.lzma2
2017/6/16:17:34:46	R	DESKTOP-2TO6PSE	Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\DirectX\DXSETUP.exe" /silent
2017/6/16:17:34:50	R	DESKTOP-2TO6PSE	DirectX Runtime return code: 0
2017/6/16:17:34:50	R	DESKTOP-2TO6PSE	Install	DirectX Runtime		CProduct::Install() return code: 0
2017/6/16:17:34:50	R	DESKTOP-2TO6PSE	Install	DirectX Runtime	Succeeded
2017/6/16:17:34:50	R	DESKTOP-2TO6PSE	Download	Play	CM	http://dds.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{54E7768D-798C-4308-895F-756BD209476D}/CM.tar.lzma2
2017/6/16:17:34:54	R	DESKTOP-2TO6PSE	Download	Aborted	CM	http://dds.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{54E7768D-798C-4308-895F-756BD209476D}/CM.tar.lzma2
2017/6/16:17:34:54	R	DESKTOP-2TO6PSE	Install	Autodesk Material Library 2018	Failed	Download Failed, Installation aborted, Result=1603
2017/6/16:17:34:54	R	DESKTOP-2TO6PSE	Rollback	DirectX Runtime		process exit code: 1619
2017/6/16:17:34:54	R	DESKTOP-2TO6PSE	Rollback	DirectX Runtime	Failed	Failure is ignored, Result=1619
2017/6/16:17:34:54	R	DESKTOP-2TO6PSE	=== Setup ended ===
2017/6/16:17:36:25	R	DESKTOP-2TO6PSE	=== Setup started on DESKTOP-2TO6PSE by R ===
2017/6/16:17:36:25	R	DESKTOP-2TO6PSE	Path_Length: 158
2017/6/16:17:36:25	R	DESKTOP-2TO6PSE	Current Directory C:\Autodesk\AutoCAD_2018_English_Win_32_64bit_wi_en-us
2017/6/16:17:36:25	R	DESKTOP-2TO6PSE	Launch
2017/6/16:17:36:25	R	DESKTOP-2TO6PSE	CommandLine	/InstallPath C:\Program Files\Autodesk /ContentPath C:\ProgramData\Autodesk /q /url "http://dds.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/AutoCAD_2018_English_Win_32_64bit_wi_en-us_Setup.exe?dummy=0" /skipPI /skipWC /Akamai /skipEULA /SN xxx-xxxxxxxx /PK 001J1
2017/6/16:17:36:25	R	DESKTOP-2TO6PSE	Current Directory C:\Users\R\AppData\Local\Temp\_AI40D.tmp
2017/6/16:17:36:28	R	DESKTOP-2TO6PSE	Download	Skipped	SETUPMARKER	http://dds.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{54E7768D-798C-4308-895F-756BD209476D}/SETUPMARKER_x64.tar.lzma2
2017/6/16:17:36:28	R	DESKTOP-2TO6PSE	Download	Skipped	SETUP_CONFIG	http://dds.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{54E7768D-798C-4308-895F-756BD209476D}/SETUP_x64.tar.lzma2
2017/6/16:17:36:28	R	DESKTOP-2TO6PSE	Install	CustomCallback	Info	Unable to get custom callback function pointer for [SETUP] CB_SOURCE=C:\Autodesk\AutoCAD_2018_English_Win_32_64bit_wi_en-us\Setup\AcSetupII.dll CB_FUNC=CustomPlatformCheck
2017/6/16:17:36:28	R	DESKTOP-2TO6PSE	Install	CustomCallback	Info	Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/6/16:17:36:33	R	DESKTOP-2TO6PSE	Download	Play	STARTMARKER	http://dds.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{54E7768D-798C-4308-895F-756BD209476D}/STARTMARKER_x64.tar.lzma2
2017/6/16:17:36:33	R	DESKTOP-2TO6PSE	Download	Complete	STARTMARKER	http://dds.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{54E7768D-798C-4308-895F-756BD209476D}/STARTMARKER_x64.tar.lzma2
2017/6/16:17:36:33	R	DESKTOP-2TO6PSE	Download	Skipped	DIRECTX	http://dds.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{54E7768D-798C-4308-895F-756BD209476D}/DIRECTX.tar.lzma2
2017/6/16:17:36:33	R	DESKTOP-2TO6PSE	Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\DirectX\DXSETUP.exe" /silent
2017/6/16:17:36:37	R	DESKTOP-2TO6PSE	DirectX Runtime return code: 0
2017/6/16:17:36:37	R	DESKTOP-2TO6PSE	Install	DirectX Runtime		CProduct::Install() return code: 0
2017/6/16:17:36:37	R	DESKTOP-2TO6PSE	Install	DirectX Runtime	Succeeded
2017/6/16:17:36:37	R	DESKTOP-2TO6PSE	Download	Play	CM	http://dds.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{54E7768D-798C-4308-895F-756BD209476D}/CM.tar.lzma2
2017/6/16:17:51:16	R	DESKTOP-2TO6PSE	Download	Play	CANCELMARKER	http://dds.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{54E7768D-798C-4308-895F-756BD209476D}/CANCELMARKER_x64.tar.lzma2
2017/6/17:11:38:54	R	DESKTOP-2TO6PSE	Download Error	CM	Network error, cannot download. Please try again later.	http://dds.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{54E7768D-798C-4308-895F-756BD209476D}/CM.tar.lzma2
2017/6/17:11:38:54	R	DESKTOP-2TO6PSE	Download	Aborted	CANCELMARKER	http://dds.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{54E7768D-798C-4308-895F-756BD209476D}/CANCELMARKER_x64.tar.lzma2
2017/6/17:11:38:55	R	DESKTOP-2TO6PSE	Rollback	DirectX Runtime		process exit code: 1619
2017/6/17:11:38:55	R	DESKTOP-2TO6PSE	Rollback	DirectX Runtime	Failed	Failure is ignored, Result=1619
2017/6/17:11:38:55	R	DESKTOP-2TO6PSE	=== Setup ended ===
2017/6/17:11:42:03	R	DESKTOP-2TO6PSE	=== Setup started on DESKTOP-2TO6PSE by R ===
2017/6/17:11:42:03	R	DESKTOP-2TO6PSE	Path_Length: 158
2017/6/17:11:42:03	R	DESKTOP-2TO6PSE	Current Directory C:\Autodesk\AutoCAD_2018_English_Win_32_64bit_wi_en-us
2017/6/17:11:42:03	R	DESKTOP-2TO6PSE	Launch
2017/6/17:11:42:03	R	DESKTOP-2TO6PSE	CommandLine	/InstallPath C:\Program Files\Autodesk /ContentPath C:\ProgramData\Autodesk /q /url "http://dds.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/AutoCAD_2018_English_Win_32_64bit_wi_en-us_Setup.exe?dummy=0" /skipPI /skipWC /Akamai /skipEULA /SN xxx-xxxxxxxx /PK 001J1
2017/6/17:11:42:03	R	DESKTOP-2TO6PSE	Current Directory C:\Users\R\AppData\Local\Temp\_AIF2E4.tmp
2017/6/17:11:42:07	R	DESKTOP-2TO6PSE	Download	Skipped	SETUPMARKER	http://dds.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{54E7768D-798C-4308-895F-756BD209476D}/SETUPMARKER_x64.tar.lzma2
2017/6/17:11:42:08	R	DESKTOP-2TO6PSE	Download	Skipped	SETUP_CONFIG	http://dds.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{54E7768D-798C-4308-895F-756BD209476D}/SETUP_x64.tar.lzma2
2017/6/17:11:42:08	R	DESKTOP-2TO6PSE	Install	CustomCallback	Info	Unable to get custom callback function pointer for [SETUP] CB_SOURCE=C:\Autodesk\AutoCAD_2018_English_Win_32_64bit_wi_en-us\Setup\AcSetupII.dll CB_FUNC=CustomPlatformCheck
2017/6/17:11:42:08	R	DESKTOP-2TO6PSE	Install	CustomCallback	Info	Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/6/17:11:42:13	R	DESKTOP-2TO6PSE	Download	Play	STARTMARKER	http://dds.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{54E7768D-798C-4308-895F-756BD209476D}/STARTMARKER_x64.tar.lzma2
2017/6/17:11:42:13	R	DESKTOP-2TO6PSE	Download	Complete	STARTMARKER	http://dds.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{54E7768D-798C-4308-895F-756BD209476D}/STARTMARKER_x64.tar.lzma2
2017/6/17:11:42:13	R	DESKTOP-2TO6PSE	Download	Skipped	DIRECTX	http://dds.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{54E7768D-798C-4308-895F-756BD209476D}/DIRECTX.tar.lzma2
2017/6/17:11:42:13	R	DESKTOP-2TO6PSE	Installing DirectX Runtime: "C:\Autodesk\WI\Autodesk AutoCAD 2018\3rdParty\DirectX\DXSETUP.exe" /silent
2017/6/17:11:42:18	R	DESKTOP-2TO6PSE	DirectX Runtime return code: 0
2017/6/17:11:42:18	R	DESKTOP-2TO6PSE	Install	DirectX Runtime		CProduct::Install() return code: 0
2017/6/17:11:42:18	R	DESKTOP-2TO6PSE	Install	DirectX Runtime	Succeeded
2017/6/17:11:42:18	R	DESKTOP-2TO6PSE	Download	Play	CM	http://dds.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{54E7768D-798C-4308-895F-756BD209476D}/CM.tar.lzma2
2017/6/17:11:44:01	R	DESKTOP-2TO6PSE	Download	Aborted	CM	http://dds.autodesk.com/NET18SWDLD/2018/ACD/D7AC923A-BC24-471F-ABC1-E578C6B5D699/WI/{54E7768D-798C-4308-895F-756BD209476D}/CM.tar.lzma2
2017/6/17:11:44:01	R	DESKTOP-2TO6PSE	Install	Autodesk Material Library 2018	Failed	Download Failed, Installation aborted, Result=1603
2017/6/17:11:44:01	R	DESKTOP-2TO6PSE	Rollback	DirectX Runtime		process exit code: 1619
2017/6/17:11:44:01	R	DESKTOP-2TO6PSE	Rollback	DirectX Runtime	Failed	Failure is ignored, Result=1619
2017/6/17:11:44:02	R	DESKTOP-2TO6PSE	=== Setup ended ===
Alfred.NESWADBA
welcome @Anonymous!
Download the installation files from Autodesk Virtual Agent >>>click<<<, then start the installation from that local file(s), using option "start as administrator", disabled antivirus.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
oswaldodcb
Hello @Anonymous
This problem has been raised in the community, and several have placed solutions, will place the links for you to apply and review solutions:
https://forums.autodesk.com/t5/installation-licensing/problem-installation-autocad-directx-runtime-failed/td-p/7077538
https://forums.autodesk.com/t5/installation-licensing/directx-runtime-failed-failure-is-ignored-result-1619/td-p/6446551
Let us know if your problem is resolved
Oswaldo Caballero
Project Engineer / Autodesk Certified Instructor / Autodesk AutoCAD Certified User and Professional
Maracaibo, Venezuela
LinkedIn
Da un Me Gusta si la publicación ha sido de utilidad y si ha resuelto tu duda presiona ACEPTAR SOLUCIÓN
The link in this post appears to be broken.
Alfred.NESWADBA
Yes, Autodesk ignored my suggestions to at least forward that old link (when they changed the structure) to the new type of AVA ... which can be found >>>here<<<.
- alfred -
Alfred NESWADBA
