block occurrences in table
john.taiariol
john.taiariol
I have a block named "cutter" used in lets say 10 occurrences. I have a table in which I list the coordinates of each block occurrence. Is it possible to first of all label each occurrence with a count number then list this number in the table. thanks in advance for any help.
oswaldodcb
Hi @john.taiariol
You can use the DATAEXTRACTION command to extract the data you need from the blocks and organize them into a table, and I will place the information to see how to apply the command:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoC...
I hope this help you,
Oswaldo Caballero
Project Engineer / Autodesk Certified Instructor / Autodesk AutoCAD Certified User and Professional
Maracaibo, Venezuela
LinkedIn
Da un Me Gusta si la publicación ha sido de utilidad y si ha resuelto tu duda presiona ACEPTAR SOLUCIÓN
john.taiariol
the count column lists "1" for each block. What I would like to do is number each block in the order of insertion in my drawing and list the numbers and positions of each block in a table. Does Autocad assign a unique name to each block inserted?
