Message 1 of 13
Problem with block reference layer color using SECTIONPLANETOBLOCK command
12:16 PM
I made two simple 3D piping lines in different layers and colors. Each pipeline is made up of block reference elbows and cylinders. When I starting produce orthographic section I using SECTIONPLANETOBLOCK command with section settings ( Background Lines > Color ByLayer > Layer "LayerByObject" ).
After section generation elbows block reference contours still in "0" layer and white color. Although in 3D elbows block reference layer is green color.
Why autocad take layer information from elements which are inside the block? I have no idea.
Any ideas how to bypass or solve this problem?
Maybe this was solved in 2018 version of AutoCAD
