The floating command text box is no longer displayed next to my cursor, it was
Message 1 of 8
The floating command text box is no longer displayed next to my cursor, it was always there as soon as I typed a letter, it would display the options, now it has disappeared and only shows in the command line at the bottom of the screen. It would also display the cursor coordinates if I clicked the mouse, but no longer. And I haven't changed anything in the settings, Thanks in advance,
Bruceybee.
Replies (7)
Message 2 of 8
user181
Set the variable DYNMODE TO 3 or click the button at the bottom of the screen as shown in the included picture.
Message 3 of 8
imadHabash
>> The floating command text box is no longer displayed next to my cursor <<
this is what F12 Dynamic Input do with special setting that you can specified from DSETTINGS command.(see below image)
Imad Habash
Message 4 of 8
Good morning imadhabash,
That has rectified the problem, Thank you very much
Bruceybee
Message 5 of 8
Thanks for your suggestion user181, imadhabash also sent a solution using the F12 key and it's worked. Thanks again anyway
Bruceebru
Message 6 of 8
worked lovley , just updated to Autocad 2021  but all my settings were put back to defualt , shame it can't transfer your personal set up when updating
Message 7 of 8
RASHIK_PANCHAL
Community Visitor
Community Visitor
This solution not working
Message 8 of 8
cadffm
it is working. If it doesn't work for YOUR issue, you have another issue.
There issue here was: Dynmode was off
Solution was: Turn it on
Ways to do it, [F12] if it was just deactivated, make sure DYNMODE is >0 (default 3)
If you want to get help, tell us what your problem is.
Do other informations working well, if not, it is possibly a graphic issue.
Rightclick -> Contextmenu appears?
Using Object snaps, the snap symbols appearing?
Productname, Productversion? Check out command ABOUT
Try this: Reset to default and answer the question about export with Yes, this export serves to save your current settings.
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-reset-AutoC...
Does it work after Reset to default?
Sebastian
