AutoCAD Forum
autocad 2025 unable to load cuix
22 REPLIES 22
Message 1 of 23
mconficconi
1664 Views, 22 Replies
It seems that on 2025 cuix are not loaded.
Is this a bug or must be rewrited cuix?
22 REPLIES 22
Message 21 of 23
pendean
in reply to: mconficconi
@mconficconi wrote:
As writed, the original ribbon works in all the pc where the add-on is installed, with the cad from 2015 to 2024, only new customer with 2025 do not show the ribbon.
Reset AutoCAD2025, or even remove and reinstall, avoid any auto-migrating options this time, then try again: no issues here at all in AutoCAD2025 either.
OR... Here are ways to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
Message 22 of 23
mconficconi
in reply to: pendean
The solution is more easy... png are not fully supported in cuix, using bmp all work done.
Message 23 of 23
pendean
We've successfully been using PNG since AutoCAD2018 I believe and never seen any issues in our offices. But luckily BMP is still an option too.
Forma Design Contest
AutoCAD Beta
