AutoCAD Forum
AUTOCAD 2025 LAYER SEARCH IN PROPERTIES MANAGER
5 REPLIES 5
clomedico
343 Views, 5 Replies
When searching for a layer in layer properties manager in AutoCAD 2025.  turning of a layer will reset the search to blank and you have to type in your search function again to get back to it.  please fix to not remove seach functions till reset as it was in 2024
5 REPLIES 5
clomedico
in reply to: clomedico
after a little testing this only appears to be happening when your searching in a xref for a layer
cadffm
I can't reproduce this on a updated ACAD2025.
Try it again with new files. Restart ACAD first.
If it is still an issue, share a screencast if possible.
Sebastian
clomedico
in reply to: cadffm
I added to it did you see you have to select an xref first to search within? also I see it happening in papers pace when in a viewport to turn of said layer in that viewport.
cadffm
I missunderstood your doing and issue.
Sorry, I can't follow you.
Step by step explaination with commandnames and more would help.
Best case: Screencast to share your steps with all of us.
Nothing attached
Sebastian
pendean
@clomedico wrote:
When searching for a layer...  please fix to not remove seach functions till reset as it was in 2024
If you find AutoCAD2024 meets your needs today, then roll back then Here are ways to open a support case with Autodesk to report your 2025 findings for a future fix, no one here is Autodesk (everyone is an end user like you):
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
HTH
State of Sustainability Webinar
AutoCAD Inside the Factory
