factor of 12? That's not the correct math, try again https://www.rapidtables.com/convert/length/inch-to-mm.html
OR
Reverse this tip, most of us show both together https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Change-e...
and
https://www.youtube.com/watch?v=tHJsHmKRs_8
Or post your DWG file, let's all have a look at your work
Assuming you only wish to change the dimension data there is a simple process in the dimension style manager.
You would first need to check if there are multiple styles being used!
If only one style is used then you could use alternate units or scale the primary units by 25.4. That scale would yeild inch measurements.
If you want to upload your drawing I can have a look and recommend the best solution.
Cheers,
Blaine
Hey,that was my bad. Tried the scale factor of 0.03 since I'm converting millimetres to feet and inches. Still wouldn't work. The measure remained in millimetres but the suffix changed to ".
For Top-Level dimensions (not nested in Blocks) it should work, this is the right way.
Possible issues:
a) Perhaps you editing the wrong dimstyle?
b) Your only checked the existing dimensions and they dimlfac is overwritten
Please create a NEW dimension, is it working for this new one?
If yes, and you are edited the right dimstyle (select one "old" dimension, command LIST, check the dimstyle of this dimension),
Is this dimscale you edited?
then the dimlfac of the existing dimension are overwritten.
Not a problem: Use Qselect to select all dimension of this dimstyle
and start command DIMOVERRIDE, DIMLFAC and then Option C
Sebastian
Please can we follow the lead of Tesla and Spacex and use metric. Did you know Imperial units are officially defined from metric base units. Metric units are defined by scientific principles. Metric is the future, imperial is going out..... Mixing units leads to drafting errors.
You can get that to the maximum precision AutoCAD is capable of, but with less code, by putting it in this way:
(/ 1 2.54)
Every reply is correct, but I would like to share my experience. Here in Panama we work with both measure systems side by side at once, plywood in feet and inches (4'x8'x1/2") and floor plans in meters. Depending if you are working in mm then the conversion 1 inch = 25.4 mm would be your choice; but if the drawing is in meters 1 meter = 39.37 inches must be used.
