AutoCAD Forum
Subtract (No solid, region, or surface)
4 REPLIES 4
Bh_GuruCharan
217 Views, 4 Replies
I was designing a bearing so I am trying to subtract the sphere and the body then it shows no solid, region, surface selected
I have checked for the solution in forums I tried explode and subtract but makes no difference.
Please some one help me!
4 REPLIES 4
Kent1Cooper
in reply to: Bh_GuruCharan
SUBTRACT can only take things of the same object type.  The spheres in the top of the ring are Surfaces, and you can't SUBTRACT a Surface from a 3D Solid.  The 14 spheres in isolation are 3D Solids, like the ring.  If I Move those over to the ring, they SUBTRACT from it just fine.
Kent Cooper, AIA
Bh_GuruCharan
in reply to: Kent1Cooper
Thanks for replying. I've tried what you said but it makes no difference
Kent1Cooper
@Bh_GuruCharan wrote:
.... I've tried what you said but it makes no difference
What does that mean?  You moved [or copied] the 3DSolid Spheres over to the Ring, but SUBTRACT doesn't work with them [as it does for me]?  Do the moved/copied Spheres actually overlap the Ring's volume so they can be SUBTRACTed from it?  Does it not accept selection of them?  Does it accept selection but the Ring does not get indentations from the SUBTRACTing?  What happens instead?  Are there any messages?  Etc., etc.
Kent Cooper, AIA
pendean
That is to be expected because
When you get a chance, convert these like this
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-FABC5079-9078-468A-8AAD-E61FEAD73815
Or swap them for these
Forma Design Contest
AutoCAD Beta
