AutoCAD 2025 keeps crashing on opening.
David125
David125
AutoCAD 2025 keeps crashing on opening, I've uninstalled and reinstalled with no change. For a couple of users in our office they have issues with graphics that do not exist with AutoCAD 2024. Do I have to wait till 2026 comes out?
imadHabash
Proposal solutions :
  • Check System Requirements ( Operating System , RAM, GPU, and Disk Space ) Verify that your hardware meets or exceeds the requirements.
  • Run a clean uninstall to remove residual files that could be causing issues ( Delete the AutoCAD folder from %AppData%, %LocalAppData%, and %ProgramData% ) \\ Remove the Autodesk folder from C:\Program Files and C:\Program Files (x86).... then Reinstall AutoCAD.
  • Check for Conflicting Software ( Disable antivirus or firewall temporarily to see if they are interfering \Check for software conflicts with tools like the Autodesk Compatibility Checker \ Close background applications using significant system resources.
  • Verify Licensing .... Ensure your AutoCAD license is active and correctly configured. If using a network license, confirm connectivity.
Imad Habash
paullimapa
"For a couple of users in our office they have issues with graphics that do not exist with AutoCAD 2024"
Make sure you've installed 2025.1.1 update for those users.
Also it's possible that the graphics cards for those users are not as compatible with 2025 than they were with 2024. So at those user's workstations launch AutoCAD 2025.1.1 and then enter the following at the command prompt:
GFXDX12
0
Close AutoCAD
Then restart AutoCAD 2025.1.1 and see if those users graphics problems have been resolved. If not, enter command GRAPHICSCONFIG, do a screenshot and share that here.
Paul Li
IT Specialist
@The Office
vinodkl
Hello @David125
Can you please tell me if you see any error when AutoCAD crashes? Did you install any windows update lately? For few users AutoCAD is crashing after updating windows. Can you try to uninstall the latest windows update and see if it helps?
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
ronniesingh
Community Visitor
Community Visitor
I guess the issue of crashing on startup arise after the new window update or graphic driver update from nvidia. After updating to autocad 2025.1.1 it is working againScreenshot 2025-03-14 003924.pngScreenshot 2025-03-15 092430.png
paullimapa
installing the latest updates is the key especially with 2025...cheers!!!
Paul Li
IT Specialist
@The Office
