AutoCAD 2025 keeps crashing on opening.
David125
Message 1 of 11
David125
AutoCAD 2025 keeps crashing on opening, I've uninstalled and reinstalled with no change. For a couple of users in our office they have issues with graphics that do not exist with AutoCAD 2024. Do I have to wait till 2026 comes out?
Replies (10)
Message 2 of 11
imadHabash
Proposal solutions :
  • Check System Requirements ( Operating System , RAM, GPU, and Disk Space ) Verify that your hardware meets or exceeds the requirements.
  • Run a clean uninstall to remove residual files that could be causing issues ( Delete the AutoCAD folder from %AppData%, %LocalAppData%, and %ProgramData% ) \\ Remove the Autodesk folder from C:\Program Files and C:\Program Files (x86).... then Reinstall AutoCAD.
  • Check for Conflicting Software ( Disable antivirus or firewall temporarily to see if they are interfering \Check for software conflicts with tools like the Autodesk Compatibility Checker \ Close background applications using significant system resources.
  • Verify Licensing .... Ensure your AutoCAD license is active and correctly configured. If using a network license, confirm connectivity.
Imad Habash
Message 3 of 11
paullimapa
"For a couple of users in our office they have issues with graphics that do not exist with AutoCAD 2024"
Make sure you've installed 2025.1.1 update for those users.
Also it's possible that the graphics cards for those users are not as compatible with 2025 than they were with 2024. So at those user's workstations launch AutoCAD 2025.1.1 and then enter the following at the command prompt:
GFXDX12
0
Close AutoCAD
Then restart AutoCAD 2025.1.1 and see if those users graphics problems have been resolved. If not, enter command GRAPHICSCONFIG, do a screenshot and share that here.
Paul Li
IT Specialist
@The Office
Message 4 of 11
vinodkl
Hello @David125
Can you please tell me if you see any error when AutoCAD crashes? Did you install any windows update lately? For few users AutoCAD is crashing after updating windows. Can you try to uninstall the latest windows update and see if it helps?
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 5 of 11
ronniesingh
Community Visitor
Community Visitor
I guess the issue of crashing on startup arise after the new window update or graphic driver update from nvidia. After updating to autocad 2025.1.1 it is working againScreenshot 2025-03-14 003924.pngScreenshot 2025-03-15 092430.png
Message 6 of 11
paullimapa
installing the latest updates is the key especially with 2025...cheers!!!
Paul Li
IT Specialist
@The Office
Message 7 of 11
David125
A couple of weeks ago I "upgraded" to windows 11. I tried installing Acad2025 again it worked fine for a couple of days, now it keeps crashing on launch.
Message 8 of 11
David125
Our IT personal tells me all our hardware exceeds requirements, I've unintstalled/reinstalled 2025 a couple of times. Updates are already installed. We don't have network license. AutoCAD 2023 works like a champ, I wish I knew why 2025 is such a DUD, I tried installing 2026 same thing, crashes on launch.
Message 9 of 11
David125
Thanks for the suggestion, I get messages that all updates have been installed..
Message 10 of 11
pendean
Community Legend
Community Legend
@David125 Start with this list
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/A-software-problem...
Then if still having issues... Here are the ways to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
You might just need more assistance than remote from way over here.
Best wishes.
Message 11 of 11
TheCADnoob
@David125 wrote:
Our IT personal tells me all our hardware exceeds requirements..
Exceeding requirements is not the same thing as being compatible with requirements (https://www.autodesk.com/support/system-requirements/certified-graphics-hardware/autocad)
In the short run until you can work out what the problem is, you can install past versions of AutoCAD. This will allow you to continue production while you troubleshoot the newer installs.
https://manage.autodesk.com/products/all
CADnoob
