txtexp moves and scales text
LeanderTorres
LeanderTorres
Example as attachment. When I try to explode the text with 'txtexp' it moves the text to another position and scales it. Is there any way to prevent this? Am I doing something wrong?
imadHabash
This is a normal behavior for 'txtexp' command.
I suggest to try WMFIN (Command). This command often keeps geometry more stable and produce polylines without moving/scaling the geometry. >> Click <<
Imad Habash
paullimapa
your UCS is rotated...change UCS to World and then type PLAN World
Paul Li
IT Specialist
@The Office
LeanderTorres
Thx, this did the trick for me.
LeanderTorres
Thank you for the reply, however this requires more steps then Paul Li's solution.
paullimapa
You are welcome…cheers!!!
Paul Li
IT Specialist
@The Office
