Looking for Pointers on Surface Creation using Line Segments in AutoDesk AutoCAD
samXPF96
Observer Observer
samXPF96
Observer
Observer
I am attempting (and failing) at creating a solid surface out of what appears to be an exploded topographical surface - it is currently just a series of line segments populating a 3D space. I have tried the usual methods - join, convert to surface, etc. End goal is to create a 3D solid out of this topography for 3D modeling / visualization. Short of converting every single triangle here into a surface and using surfsculpt, etc., I am out of ideas.
parkr4st
post again with the file attached for the lines.  easier to work with the data.
samXPF96
Observer
Observer
Just updated the post with the .dwg file, thanks. Didn't know that was an approved action here. Appreciated.
leeminardi
It looks like you have a TIN (Triangulated Irregular Network) that was unfortunately exploded down to just individua line segmments for each triangle. Do you hav acess to Civil 3D?  I believe it has a ffeature for creating surface from point data.
Alternatively, you could maually create 3DFACES for each set of lines that defines a triangle. It would be tedious but it will give you objects that you can convert to regions that then can be used with SURFSCULPT to create a solid given additonal surfaces (or regions) that define a water tight volume.
lee.minardi
samXPF96
Observer
Observer
Thank you for looking into this. I had a concern that it was too far exploded to recover from - this all but confirms it. I do not have access to civil 3D, and the 3D faces approach is what I had been trying to avoid, mainly because the visualization exercise is likely not worth the effort.
Appreciate the suggestions here!
parkr4st
using DATAEXTRACTION extracted starting end points and finishing end points of the lines and put those into .txt files
In MAP3d MAPIMPORTED the starting end point data   attached in the .txt file.
The points in the dwg are distorted as they sit on Maine state plane west grid and there was no coordinate system in the original dwg
Map3d can produce a surface from the points as well as civil3d and other software may produce a surface without a geocoordinate requirement.
the surface can be produced with the correct software
autoid374ceb4990
I don't know if this will help you, but I took your Topo-Lines-WB.dwg file and converted the lines to 3DFACE's. The 3DFACES are in the TIN layer.
The file is in R14 format.  Years ago I wrote software (ARX files) to convert survey data to TIN's for earthwork computations.
