AutoCAD Forum
AutoCAD 2023 - Can't enable fast shade mode
3 REPLIES 3
Mohamed.Abdelbasit
974 Views, 3 Replies
Mohamed.Abdelbasit
I can't enable the fast shaded mode, I have typed the command "FASTSHADEDMODE" and showed the current value was <OFF> but it didn't accept the change
[ The subject line of this post has been edited for clarity by @handjonathan Original: Can't enable fast shaded mode in AutoCAD 2023 ]
3 REPLIES 3
handjonathan
Hi @Mohamed.Abdelbasit
Thanks a lot for posting your question to the forums!   Can you select enter when changing the variable from [OFF] to [ON] ?
It would also be good if you can share an image in the command line once complete.  Selecting F2 will show this info.
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Jonathan Hand
Mohamed.Abdelbasit
I found the cause of the problem, the "Hardware Acceleration" in "GRAPHICSCONFIG" was OFF
i have enabled it ,restarted Autocad, and it worked fine
handjonathan
Perfect @Mohamed.Abdelbasit
Glad you got it all sorted.
Jonathan Hand
Jonathan Hand
AutoCAD Inside the Factory
