Announcements
AutoCAD - How to put 2d text in a 3d dimension?
hnguy157
Observer
hnguy157
Observer
Observer
How can i put the metric text box in the 3d layout like this hw?
[ The subject line of this post has been edited for clarity by @handjonathan Original: How to put 2d text in a 3d dimension? ]
pendean
Community Legend
Community Legend
Your image is not a "3D", it's an isometric
This tutorial should help you add dimensions and text to match your image https://www.thesourcecad.com/how-to-make-isometric-dimension-and-text-in-autocad/
Explore ISO Drafting in AutoCADLT in HELP, I'll get you started with the first page here https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/Au...
hnguy157
Observer
Observer
thank you
hnguy157
Observer
Observer
oh and i can do most of the other dimension. I just don't know how to put the metric box, like most of the other stuff is on xyz but the metric box is just xy,
pendean
Community Legend
Community Legend
@hnguy157 wrote:
...I just don't know how to put the metric box....
Check out this tip https://www.cadlinecommunity.co.uk/hc/en-us/articles/205205002-AutoCAD-2016-Placing-a-box-around-tex...
dany_rochefort
@hnguy157  To get your text back flat onto the XY plane in Modelspace after your isometric detailing, simply type UCS at the command line and select View or V at the UCS prompt line. You will get back to 2d UCS on xy plane.
You could also put 2d text on a viewport in Paperspasce looking onto your isometric detail in modelspace.
pendean
Community Legend
Community Legend
@dany_rochefort @hnguy157 or... modelspace content in a viewport in a layout, and the boxed label of the drawing is in paperspace outside of the viewport.
