I can't enable the fast shaded mode, I have typed the command "FASTSHADEDMODE" and showed the current value was <OFF> but it didn't accept the change
[ The subject line of this post has been edited for clarity by @handjonathan Original: Can't enable fast shaded mode in AutoCAD 2023 ]
Solved by Mohamed.Abdelbasit. Go to Solution.
Thanks a lot for posting your question to the forums! Can you select enter when changing the variable from [OFF] to [ON] ?
It would also be good if you can share an image in the command line once complete. Selecting F2 will show this info.
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
I found the cause of the problem, the "Hardware Acceleration" in "GRAPHICSCONFIG" was OFF
i have enabled it ,restarted Autocad, and it worked fine
Perfect @Mohamed.Abdelbasit
Glad you got it all sorted.
Jonathan Hand
