In AutoCAD 2018 we've been having an issue when inserting multiple blocks in a single cell in an AutoCAD table. It causes the cell height to increase dramatically. This only occurs when there are multiple blocks in a cell. This does not happen with cells that have only one block inserted. Every time we fix the table it always goes back to being messed up.
Has anyone encountered this? If so, were you able to find a solution?
Thanks in advance for the help!
Hi @LOrtizACCO,
This type of formatting is pretty limited. If you can provide a sample drawing with your table and the blocks I would like to take a look. In the past, I have combined blocks into a new block to do this but perhaps that is not what you are looking for.
Hi @LOrtizACCO,
Unfortunately, the attachment did not stick. Please try again (don't use email-use a web browser) so I can take a look at your sample.
Hi @LOrtizACCO,
This is the way I have dealt with this issue in the past. I took the three individual blocks and turned them into a new block that can be inserted in the table cell.
Hi @LOrtizACCO,
I am coming back to your thread to see if the issue or question you posed has been resolved. If so, please mark the post or posts as Solution(s) to help others find the answer quickly. If your issue persists, please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Hi @LOrtizACCO,
Can you walk through the steps that you believe create this issue? I can insert multiple blocks in a cell in your table without the cell height being screwed up.
Have tried the different options available to Manage Cell Content?
