- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
AutoCAD 2017 gets stuck when saving or opening files with X-refs, where AutoCAD 2016 does not. The CPU processes one core at max, indefinitely. I can repeat the same tasks in 2016 on the same files, and have no issue.
Files are very clean, before you ask.
Machine has 2017 and 2016 installed at same time.
Oddity, if I copy all the files to the same desktop, then I can xref, and save/open the file without issue.
Folder where files are normally stored (D:\ drive of local computer), using MKLINK /j (junction) to redirect to c: drive.
Saved paths are full path, not relative.
Please help.
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
