AutoCAD Forum
autocad 2017 laydel command
7 REPLIES 7
Message 1 of 8
dlcurry
929 Views, 7 Replies
I have found that the LAYDEL command does not work in autocad 2017. I use the command as I always have, select the layers by name, I'm prompted to confirm layer deletion, I accept, but the layers are not deleted.
Tags (1)
7 REPLIES 7
Message 2 of 8
Patchy
in reply to: dlcurry
Is it LOCKED? is it the CURRENT LAYER?
Message 3 of 8
john.vellek
Hi @dlcurry,
Is this happening in all drawings or just select ones? I use laydel and it works fine in my AutoCAD 2017.
Can you prepare a screencast video or take some screenshots of what you are experiencing?
BTW, are you a local administrator on your computer?
John Vellek
Message 4 of 8
imadHabash
herewith some causes and solutions >> Link << .
Good Luck...
Imad Habash
Message 5 of 8
GrantsPirate
I just tried it on 2017.1 on a Win7 machine, it works just fine picking by name or picking on an object.  Post a drawing or portion of one where it doesn't work.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 6 of 8
john.vellek
Hi @dlcurry,
Did your problem with Laydel get fixed? Is this happening in only one drawing or all drawings? If the layer unlocked? is it in an XREF?
Please give me some more detail.
John Vellek
Message 7 of 8
i have the same issue with my mac machine.. please help
Message 8 of 8
Alfred.NESWADBA
If the above suggestions do not help: Please upload the drawing + let us know the name of the layer you like to delete.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Forma Design Contest
AutoCAD Beta
