AutoCAD Forum
Autocad 2016 opening file error
3 REPLIES 3
549 Views, 3 Replies
When I want to open a file using ctrl+o or using the folder button the file dialog (is it called that way?) box does not appear. The screen freezes untill I press escape and in the command line bar _open appears as if I had opened a file.
I tried filedia but that doesn't solve it.
Does anyone have any idea?
3 REPLIES 3
M_Hensley
It could be the box is appearing off the screen where you can't see it. Hold down ALT+SPACE+M then tap one of the directional arrow keys and now move the mouse and the box should attach to your cursor.
in reply to: M_Hensley
Thanxs for the tip, but it didn't work out. The box just isn't there.
When I hold down ALT+SPACE+M a fold down menu appears but with nothing I can use.
I've added some pictures where you can see what happens. In the left corner of the printscreen you can see the ALT+SPACE+M result.
Finally I reset my autocad to basic settings and now it is fixed. But I still don't what happened.
Forma Design Contest
AutoCAD Beta
